Alphacool Apex Grip SoftTube fitting 16/10mm G1/4 black Set 6 pcs
- Article no.: 14923
- EAN: 4250197149235
- Weight: 0,18 kg
| Technical Data | |
| Height | 18,50mm |
| Diameter | 23,50mm |
| Material | Brass |
| Material Grip Surface | Silicone |
| Threads | G1/4 |
| Thread Length | 5mm |
| Softtube compatibility | 16mm outer diameter (OD); 10mm inner diameter (ID) |
| Color | black |
Warranty: 5 years
