  • 13016
  • 4250197130165
  • 0,14 kg
Content: 100 Milliliter (€99.80 * / 1000 Milliliter)
WZS Alphacool Apex filling funnel G1/4"
€8.98*
17634 Alphacool ES deionized water (ultrapure water) 1000ml
€15.98*
17635 Alphacool ES deionized water (ultrapure water) 5000ml
€69.98*
17313 Alphacool Ultra Pure Water 1000ml
€6.98*
To maintain the cooling performance of a water cooling system, regular maintenance is necessary.... more
To maintain the cooling performance of a water cooling system, regular maintenance is necessary. That's why Alphacool has developed the Core Loop Cleaning Liquid. The additives contained effectively protect the loop from corrosion, limescale and other contaminants. The Core Cleaning Liquid is essential for the next cleaning.
Simple and Effective!
The concentrate should only be mixed with distilled water or Alphacool Ultra Pure Water without additives, not with tap water! Depending on the degree of contamination, the mixture runs through the water loop until the desired result is achieved.
Attention: The mixture should not run through the system for more than 30 minutes at a time! Prolonged use beyond this time frame can lead to damage to the nickel- or chrome plating. Furthermore, we recommend using the Cleaning Kit exclusively for Alphacool components. No liability for damage to third-party products.
Then the mixture is drained, and the components are rinsed again with distilled water. This removes all residues and ensures long-term protection of the components. Afterward, the loop can be refilled with any desired liquid.
Mixing proportion:
One bottle of Core Loop Cleaning (100ml) to 1 liter of distilled water.
Information:
The cleaning solution dissolves dirt and deposits from surfaces. However, they are not dissolved. Therefore, it may happen that the dissolved dirt gets trapped in the cooling fins and may cause clogging. It is recommended to thoroughly rinse the coolers with distilled water. For a complete cleaning, it is also advisable to disassemble the cooler and clean the cooling fins separately with, for example, a soft toothbrush.
Filling quantity100ml
ContainsCitric Acid Monohydrate
Safety notes
Warning
  • Causes serious eye irritation.
  • Wash hands thoroughly after handling.
  • Wear protective gloves/protective clothing/eye protection/face protection.
  • IF ON SKIN: Wash with plenty of water.
  • IF IN EYES: Rinse cautiously with water for several minutes. Remove contact lenses if present and easy to do – continue rinsing.
  • If eye irritation persists get medical advice/attention.
  • Take off contaminated clothing and wash it before reuse.
  • Causes skin irritation.
  • If skin irritation occurs: Get medical advice/attention.
€29.98 *
€1.78 *
20% Black Friday Rabatt
