Alphacool Eiszapfen temperature sensor flat G1/4 - Black
  • 17596
  • 4250197175968
  • 0,022 kg
€10.98 *
17350 Alphacool Eisfluegel flow indicator G1/4 square - acetal
€18.98*
17464 Alphacool Eisfluegel Aurora flow indicator "HighFlow" with RPM-Signal
€38.98*
29142 Alphacool Eiszapfen Acryl/Acetal Inline filter G1/4 inner thread
€12.98*
17558 Alphacool ES flow and temperature indicator "HighFlow" with RPM-Signal
€41.98*
17573 Alphacool Core Temperature Sensor with C/F Display
€14.98*
The Alphacool Eiszapfen temperature sensor flat G1/4" is a simple water temperature sensor that... more
The Alphacool Eiszapfen temperature sensor flat G1/4" is a simple water temperature sensor that can be easily integrated into any water loop.
Integration made easy
The temperature sensor is very compact and can be integrated into any water circuit due to its G1/4" external thread. It is simply screwed into the corresponding G1/4" connection at any position in the water loop. Due to the small screw-in depth, it is compatible with all Alphacool products with a free G1/4" connection.
Sensor
A classic NTC 10 kOhm thermistor is used as sensor. The readable temperature range is between -40 and 125°C. The cable is 40 cm long and leads into a typical 2-pin connector. Many mainboards now offer direct connection options for such sensors. Please check the manual of your mainboard. Of course there are also several external controllers that offer a connector for the sensor.
Design
The design is very simple so that the temperature sensor can be installed almost invisible in the system.
G1/4" female connectors
H x D17 mm x 18 mm
Materialbrass
Pressure test8 bar
Cable length40 cm
Connection2-Pin
ThermistorNTC 10 kΩ
ThreadG 1/4 IT
Thread length5 mm
Total screw-in depth13 mm
