Alphacool Eisfluegel Aurora flow indicator "HighFlow" with RPM-Signal
- Article no.: 17464
- EAN: 4250197174640
- Weight: 0,2 kg
For anyone who would like to measure their water flow and values a great look, the Alphacool Eisfluegel Aurora is the perfect choice. It can be easily installed anywhere in the water cooling circuit and offers outstanding lighting.
High-Flow Sensor
The Eisfluegel is designed for high flow systems and can display a water flow of 70 to 300L/h. The speed of the Eisfluegel Aurora is read out via the 3-pin connection at a corresponding fan connection on the mainboard. This can then be used to determine the flow. Since the Eisfluegel is made of Plexi, the flow can also be easily determined visually.
Digital RGB LEDs
The Eisfluegel has 8 addressable digital RGB LEDs that run around the impeller and form a circle. Since each LED can be controlled individually, any effect that the respective controller can produce can be created. The connection is made via a 3-pin JST plug, which makes the Eisfluegel compatible with all other digital RGB products from Alphacool. If you prefer to control it directly via the mainboard, for example, you can use the included 3-pin 5V adapter.
Integration into the water cycle
Two G1/4" threads are available for installation in a water circuit. It is up to the user to decide which is used as IN or OUT. The Eisfluegel flow sensor is light and can therefore be positioned freely hanging in the system. On the underside of the Eisfluegel there are two screwing options for the included M3 screws. This allows the flow sensor to be placed anywhere in the housing. The scope of delivery also includes a small self-adhesive Velcro mat that can also be used to mount the Eisfluegel.
Danger:
The Eisfluegel Aurora flow indicator "HighFlow" only works from a flow rate of 70L/h!
| Technical data | |
| Dimensions (L x W x H) | 45 x 45 x 39.4 mm |
| Material | Plexi |
| Connections | 2x G1/4" |
| Digital RGB LED connection | 3-pin JST (adapter to 3-pin 5V is included) |
| Speed sensor connection | 3-pin fan connector |
