Alphacool Eisfluegel flow indicator red 6-11mm - acrylic
- Article no.: 17357
- EAN: 4250197173575
- Weight: 0,019 kg
Alphacool Eisflügel: The flow indicator with added value!
Water cooling in a computer always serves to improve the appearance. Neatly laid hoses or hard tubes create an impressive image. The Alphacool ice wing can also be used to create a real eye-catcher. The silent rotation of the impeller always shows the direction of flow.
- Dimensions: 88 x 40 x 15mm
- pressure load up to 2 bar, max.
- Connection: for hoses with an inner diameter of 6-11mm.
- Material: ABS
Scope of delivery
- 1x Alphacool Eisfluegel flow indicator red 6-11mm - acrylic
