- Article no.: 17453
- EAN: 4250197174534
- Weight: 0,054 kg
*1The new fittings in Alphacool's Enterprise Solutions series were specially developed for Alphacool's TPV hoses. They have a very high tensile strength thanks to a locking ring, which consists of a metal ring and hooks into the hose. They not only stand for safety, but also for durability. Since they are made of nylon, they are extremely durable and can be used with copper and aluminum parts in the water circuit without any problems, because nylon does not react with other materials.
Technical Data:
- Material: Polyester
- Color: Black
- Length: 28mm
- Diameter: 20.5mm
- Thread: G1/4“
- Thread length: 5.5 mm
- Hose size: 12.7 / 7.6 mm
