Alphacool HF compression Fitting TPV - 12,7/7,6mm Straight - Black
- Article no.: 17637
- EAN: 4250197176378
- Weight: 0,008 kg
As part of the Alphacool Enterprise Solutions product line, the TPV fittings made of nylon were specifically designed for the use with TPV hoses. In combination with the appropriate TPV hose, this fitting ensures remarkable tensile strength.
Enterprise Solutions fitting?
Until now Alphacool used these TPV water cooling fittings for servers and workstations exclusively where durability and safety are of utmost importance. To meet these requirements, straight TPV fittings have a locking collar that secures the hose. This collar consists of a metal ring inside the fitting that latches onto the hose with hooks, preventing the TPV hose from being pulled out under normal conditions.
Nylon as material
The fitting is made of nylon to keep weight to a minimum. Nylon is not only highly resistant but also extremely durable. Additionally, nylon is compatible with copper and aluminum parts in the water loop, and it does not react with other materials in the system.
| Technical data | |
| Dimensions (L x D) | 28 x 20,5mm |
| Material | Nylon |
| Pressure test | 8 bar |
| Thread | G1/4“ |
| Thread length | 5mm |
| Tube size | 12,7/7,6mm |
| Color | black |
Warranty: 5 years
