Alphacool HF compression Fitting TPV Metall - 12,7/7,6mm Straight - Black
  • 17638
  • 4250197176385
  • 0,02 kg
  • 5
€6.48 *
€19.98*
€12.98*
€18.98*
€31.98*
€10.98*
The Alphacool TPV metal fitting originates from Alphacool’s Enterprise Solutions product line.... more
The Alphacool TPV metal fitting originates from Alphacool’s Enterprise Solutions product line. It was specifically designed for use with Alphacool TPV hoses.
Enterprise Solutions fitting?
Until now Alphacool used these TPV water cooling fittings for servers and workstations exclusively. In combination with the appropriate TPV hose, the metal fitting can be tightened particularly firmly, resulting in remarkable tensile strength. During the development, special attention was paid to the usage of space-saving components. Compared to the nylon variant, the Alphacool TPV metal fitting is even shorter by whole 4mm.
Dimensions (L x D)24 x 18mm
Materialbrass/aluminium
Pressure tested4.2 bar
Max working temperature60°C
ThreadG1/4”
Thread length5,5mm
Hose size12,7/7,6mm
Warranty: 5 years
€34.98 *
€27.98 *
