Alphacool Eisblock XPX Pro 1U
- Article no.: 12936
- EAN: 4250197129367
- Weight: 1,016 kg
The Alphacool Eisblock XPX Pro 1U is part of the latest generation of CPU water coolers offering you great performance.
Optimized flow
The Alphacool Eisblock XPX Pro 1U has a large cooling surface area so that the water can flow completely over all CPU cores. This means that even large server CPUs are no longer a problem.
Versatility
With three G1/4 inlet ports and five G1/4 outlets the Eisblock XPX Pro 1U offers versatile connectivity in almost any direction. Thanks to the different mounting brackets that Alphacool includes with each XPX Pro Eisblock it is compatible with Intel LGA 2066, Intel LGA 3647 and AMD TR4/SP3. Simply select your mount and mount it.
Perfect fit
The Alphacool XPX Pro 1U CPU Cooler is suitable for all U1 (H1) racks and cases. The extremely flat design also gives you the freedom you need in your system.
Intel: LGA 1700 / LGA 1851 / LGA 2011-3 / LGA 2066 / LGA 3647 / LGA 4189 / LGA 4677 (optional) / LGA 4710 (optional)
| Technical data | |
| Dimensions | 79 x 63.8 x 25.5 mm |
| Weigth | 205 g |
| Pressure tested | 8 bar |
| Material cooling plate | nickel plated copper |
| Material cooler top | Nylon |
| Connections | 3 x G 1/4 (IN) ; 5x G 1/4 (OUT) |
