Alphacool Eiswasser Crystal Green UV-active premixed coolant 1000ml
- Article no.: 18545
- EAN: 4250197185455
- Weight: 1,1 kg
*1With Alphacool Eiswasser, water cooling pioneer Alphacool is checking off every modder and enthusiast’s wish list: brilliant colours, cool effects in plexi coolers, tubing and reservoirs, as well as a long lifespan and material compatibility. The Alphacool Eiswasser Crystal Series has been tested in every possible application both in Alphacool’s lab and by external testers and modders, and was proven to be high-quality and long-lasting.
| Technical data | |
| Content | 1000ml |
| Specification | Ready mix |
| Color | green |
| UV ink | green |
| Manufacturer | Alphacool |
