Alphacool Acrylic Tube Double Bending Tool 12-14mm and 16mm - Black
- Article no.: 29124
- EAN: 4250197136235
- Weight: 0,079 kg
Alphacool has now developed a bending tool for different sizes which makes laying and bending the HardTubes child's play!
HardTubes with a thickness of 12 - 14mm as well as 16mm are no problem. Curves of up to 180° can be bent easily and cleanly. With the help of the red rubber length limiters, the straight part of the tube can be adjusted in centimeter increments.
Technical data:
- Material: Polyester
- Color: black
- HardTube sizes: 12 - 14mm, 16mm
- Angle: 0° - 180°
- Dimensions (LxWxH): 178 x 137 x 20mm
- 1x Alphacool Acrylic Tube Double Bending Tool 12-14mm and 16mm - Black
