Alphacool Eiszapfen 2-way ball valve G1/4 - Chrome
- Article no.: 17141
- EAN: 4250197171410
- Weight: 0,09 kg
Alphacool's Eiszapfen series is groundbreaking and is characterized by excellent workmanship and high flow.
Ball valves have always been a flow restriction and made life difficult for every pump. Alphacool has therefore developed a ball valve that does not pose an obstacle up to a diameter of 10mm.
The ball inside seals completely tightly and prevents any further liquid leaking out. All 1/4" connections with a maximum thread length of 6mm can be screwed in on both sides.
This ball valve is available in two different colours: Chrome and deep Black
Dimensions (L x W x H): 35.4 x 36 x 22.7mm
Color: Chrome
Inner diameter: 10mm !!!HIGHFLOW!!!
Scope of delivery
