  • 17477
  • 4250197174770
  • 0,246 kg
€39.98 *
Content: 6 Stück (€6.66 * / 1 Stück)
€10.98*
S16 Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 60cm - Set of 4 (240cm)
€19.98*
S16 Alphacool Ice Tube 16/13mm Acrylic (PMMA) HardTube Satin 80cm - Set of 4 (320cm)
€38.98*
SZ Alphacool Acrylic Tube Double Bending Tool 12-14mm and 16mm - Black
€17.98*
ANS Alphacool Eiszapfen PRO 16mm HardTube fitting G1/4 - deep black -
€7.98*
€1.98*
The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the... more
The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the well-known Eiszapfen. When developing the fittings, Alphacool focused specifically on a specific problem: the deformation of PETG HardTubes at high temperatures. These can deform at as little as 60°C. Although such a temperature is rarely reached, it can still occur. The Eiszapfen PRO prevent this problem from the outset and hold the tubes in position.
Technical Data
Dimension (D x L)26mm x 23mm
MaterialBrass
ThreadG1/4"
Thread lenght5mm
HardTube size16mm
CompatibilityPETG, acrylic, brass and glass tubes
Weight4,2g
€28.98 *
€38.98 *
€1.98 *
€26.98 *
