Alphacool HT 16mm HardTube screw-on nozzle G1/4 - knurled - Chrome
  • 17195
  • 4250197171953
  • 0,046 kg
  • Currently there are 8 available
€5.28 *
S16 Alphacool HardTube 16/12mm Acrylic (PMMA) Clear 20cm EOL
€0.99*
With the new screw-on nozzles from Alphacool for acrylic brass tubes, Alphacool takes another... more
With the new screw-on nozzles from Alphacool for acrylic brass tubes, Alphacool takes another step towards perfection and quality.
The first two colors, Chrome and Deep Black, offer great variety. The completely coordinated product series lets each system shine in its own way and there are no limits to individuality when combined with Alphacool acrylic brass tubes!
A new chromating process firmly bonds the coloring to the brass base. This ensures the longevity of the intense color and prevents the chrome layer from chipping. Alphacool lettering on the connections further highlights the special nature of these items.
This connector is used to connect a 16mm acrylic brass tube with a 1/4 inch thread.
Technical details:
Material: brass, chromated
Color: Chrome
Dimension:
Width: D25.5mm
Height: 23mm
1 x Alphacool HT screw-on nozzle G1/4 for acrylic brass tubes - Chrome
€28.98 *
62%
€0.99 * €2.59 *
€1.78 *
€26.98 *
ANS Alphacool HT 16mm HardTube Anschraubtülle G1/4 - gerändelt - Chrome Sixpack PHT EOL
Alphacool HT 16mm HardTube screw-on nozzle G1/4 - knurled - Chrome Sixpack
€28.98 *
S16 Alphacool HardTube 16/11mm Borosilikatglas 40cm
Alphacool HardTube 16/11mm borosilicate glass 40cm
Content 40 Zentimeter (€29.95 * / 100 Zentimeter)
€11.98 *
Alphacool D-RAM module (for Alphacool D-RAM cooler) - black 2 pieces
Content 2 Stück (€11.99 * / 1 Stück)
€23.98 *
