Alphacool Eiszapfen 16mm HardTube screw-on nozzle 90° rotatable G1/4 - Chrome
  • 17394
  • 4250197173940
  • 0,084 kg
€10.98 *
Design: 90° screw-on nozzle 16mm
This connector has a 1/4" thread on one side and is therefore compatible with 95% of all components. The other side is suitable for a 16mm acrylic and brass tube. In the middle, this connector is angled at 90° to avoid complicated hose routes. For maximum flexibility, the side with the thread can be rotated.
  • Material: Brass
  • Color: Chrome
dimension
  • Length: 45mm
  • Width: 29mm
Scope of delivery
  • 1x Alphacool Eiszapfen 16mm HardTube screw-on nozzle 90° rotatable G1/4 for acrylic brass tubes - Chrome
Here you will find an interactive overview of all Alphacool connections.
€26.98 *
€28.98 *
€38.98 *
ANS Alphacool HT 16mm HardTube Anschraubtülle G1/4 - gerändelt - Chrome Sixpack PHT EOL
Alphacool HT 16mm HardTube screw-on nozzle G1/4 - knurled - Chrome Sixpack
€28.98 *
