Alphacool HT 16mm HardTube screw-on nozzle G1/4 - knurled - Chrome Sixpack
  • 17384
  • 4250197173841
  • 0,17 kg
€28.98 *
Content: 6 Stück (€4.83 * / 1 Stück)
With the new screw-on nozzles from Alphacool for acrylic, brass or carbon tubes, Alphacool is... more
With the new screw-on nozzles from Alphacool for acrylic, brass or carbon tubes, Alphacool is taking another step towards perfection and quality.
The first two colors, Chrome and Deep Black, offer great variety. The completely coordinated product series lets each system shine in its own way and there are no limits to individuality when combined with Alphacool acrylic brass tubes!
A new chromating process firmly bonds the coloring to the brass base. This ensures the longevity of the intense color and prevents the chrome layer from chipping. Alphacool lettering on the connections further highlights the special nature of these items.
This connector is used to connect a 16mm acrylic, brass or carbon tube to a G1/4" thread.
Six-pack:
Since six connections of one type are often required, Alphacool now offers six-packs. This offers many advantages from which you can benefit!
Technical details:
  • Material: brass, chromated
  • Color: Chrome
  • 1 x Alphacool HT 16mm HardTube screw-on nozzle G1/4 for acrylic brass tubes - knurled - Chrome Sixpack
€28.98 *
€26.98 *
€38.98 *
Alphacool HardTube 16/13mm 90° acrylic (PMMA) 20/40cm
Content 60 Zentimeter (€21.63 * / 100 Zentimeter)
