Alphacool Eiszapfen PRO 16mm HardTube Fitting G1/4 - Chrome
- Article no.: 17472
- EAN: 4250197174725
- Weight: 0,056 kg
*1The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the well-known Eiszapfen. When developing the fittings, Alphacool focused specifically on a specific problem: the deformation of PETG HardTubes at high temperatures. These can deform at as little as 60°C. Although such a temperature is rarely reached, it can still occur. The Eiszapfen PRO prevent this problem from the outset and hold the tubes in position.
Technical details:
- Material: Brass
- Color: Chrome
- Diameter: 26mm
- Height: 23mm
- Thread: G1/4"
- Thread length: 5 mm
- HardTube Size: 16 mm
- Compatibility: PETG, acrylic, brass and glass tubes
- Weight: 0.042kg
- Scope of delivery: 1x Alphacool Eiszapfen PRO 16mm HardTube Fitting G1/4 - Chrome
