Alphacool Core Geforce RTX 5090 Suprim + Vanguard + Gaming Trio with backplate
- Article no.: 10268
- EAN: 4250197102681
- Weight: 1,891 kg
*1Alphacool introduces its new series of graphics card water coolers for the latest Nvidia GeForce RTX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
- MSI GeForce RTX™ 5090 32G GAMING TRIO OC
- MSI GeForce RTX™ 5090 32G SUPRIM LIQUID SOC (MS-V530 Ver:2.1)
- MSI GeForce RTX™ 5090 32G SUPRIM SOC (MS-V530 Ver:2.1)
- MSI GeForce RTX™ 5090 32G Vanguard SOC
- MSI GeForce RTX™ 5090 32G Vanguard SOC Launch Edition
| Technical data cooler | |
| Dimensions total (L x W x H) | 222,40 x 160,81 x 34,12mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 10 |
| Color | transparent |
| Dimensions (L x W x H) | 222,40 x 132,24 x 6mm |
| Thick backplate without spacers | 3mm |
| Material | Aluminium |
