Alphacool Eisblock Aurora Acryl GPX-N Geforce RTX 3070 FTW3 Ultra with Backplate
  • 11970
  • 4250197119702
  • 1,819 kg
€39.98 *
€19.98*
€18.98*
€12.98*
€14.98*
The Alphacool Eisblock Aurora Acrylic GPX graphics card water cooler with backplate combines... more
More performance!
During the development of the Eisblock Aurora Acryl GPX graphics card water cooler, emphasis was naturally placed on increasing performance. First, the cooler was brought closer to the individual components by reducing the thickness of the heat conducting pads. Next, the chrome-plated copper block was also made thinner. Step 3 involves the constant optimisation of the water flow within the cooler. The result: All important components such as voltage converters and RAM are cooled much better and more effectively by the water and the cooling performance increases significantly.
Brilliant design!
Copper or aluminium?
Alphacool uses only copper for all water-bearing parts. Copper has almost twice the thermal conductivity of aluminum and is therefore clearly the better choice of material for water cooling. The cooler is made entirely of chrome-plated copper. A chrome plating is much harder than a nickel plating and therefore less sensitive to acids, scratches and damage. It completely eliminates the risk of chipping nickel plating. Additionally, chrome plating looks much more homogeneous and provides a shine that cannot be achieved by nickel plating.
Other special features
- EVGA GeForce RTX 3070 FTW3 Ultra Gaming (08G-P5-3767-KR)
- EVGA GeForce RTX 3070 Ti FTW3 Ultra Gaming (08G-P5-3797-KL)
Technical data cooler
L x W x H288.5 x 149.5 x 24 mm
Material cooler topacrylic
Threads4 x G 1/4
Thickness cooling fins0.6 mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5 V
Number of digital aRGB LEDs13
Technical data backplate
L x W x H288.5 x 134 x 6 mm
Materialaluminium
€38.98 *
€83.98 *
€23.98 *
€1.78 *
Delivery date: in 2 - 3 weeks
Alphacool NexXxoS ST30 Full Copper 240mm radiator
€51.98 *
