Alphacool Eiszapfen 13mm HardTube compression fitting 90° rotatable G1/4 - White
  • 17620
  • 4250197176200
  • 0,074 kg
€10.98 *
Alphacool's Eiszapfen connector series is the high-end execution of these tried-and-true... more
Alphacool's Eiszapfen connector series is the high-end execution of these tried-and-true fittings!
Everything you want in a compression fitting is here: highflow, form, processing and colour. A refusal to compromise in development and production has made the Eiszapfen series into what it is.
A special procedure binds the outer coating firmly to the surface, improving the longevity of the intense colour and preventing any chipping or peeling of the coating. Every connector now has the Alphacool logo, which along with their distinctive shape makes them unmistakable!
The union nut's slanted corners allow the O-ring to be pressed firmly against the HardTube, ensuring it sits even more securely than before. This allows for greater safety in transport.
Model: 90° compression fitting 13mm
This fitting has a 1/4" thread on one side and is thereby compatible with 95% of components. The other side fits a 13mm acrylic or brass tube. This fitting is bent 90° in the middle to avoid complicated hose connections. The threaded side is rotatable for maximum flexibility.
Dimensions (L x W)42.5 x 21.00mm
Materialbrass
ThreadsG1/4" OT | 13mm (OD 1/2")
Thread length5mm
Possible rotation360°
Version90° angled
Colorwhite
€38.98 *
€25.98 *
€20.98 *
€23.98 *
WAC Alphacool Core 1 White
€115.98 *
Alphacool HardTube 13/10mm 90° acrylic (PMMA) 20/40cm
Content 60 Zentimeter (€18.30 * / 100 Zentimeter)
€10.98 *
