  • 29138
  • 4250197136266
  • 1,03 kg
€41.98 * €59.98 * (30.01% Saved)
€10.98*
18444 Alphacool HardTube 16/13mm Acryl clear 80cm - 4pcs
€28.98*
€25.98*
S13 Alphacool Ice Tube 13/10mm PETG HardTube 60cm - Set of 4 (240cm)
€17.98*
WZS Alphacool pull saw for acrylic/PETG pipes 35cm
€17.98*
SZ Alphacool ice case - measuring kit
€26.98*
SZ Alphacool ice case - bending plate
€20.98*
More and more water cooling fans are opting for HardTubes for aesthetic and practical reasons.... more
More and more water cooling fans are opting for HardTubes for aesthetic and practical reasons. The user is faced with the great challenge of bending the tubes to fit the water circuit. To ensure that this is successful, the Alphacool Eiskoffer Light contains most of the tools required to bend the HardTubes optimally. All you need is a hot air gun and a saw to cut the HardTubes to the desired length. This not only ensures that the water cooling system looks great, but also makes assembling the water cooling system much easier.
The Alphacool Eiskoffer Light includes a large circular arc and a multi-arc feeder. This makes it easy to create any angle you want. All feeders are designed for HardTubes with an outer diameter of 13 or 16 mm. Two fitting stops are included so that you can measure the correct length when bending. These simulate the depth of the icicle fittings. Four additional feeders with pin stops can be used in a variety of ways. Either as support to achieve several bending radii at the same time, or as an end stop point.
All supports and stops can be screwed onto any wooden board. The appropriate wood screws are included in the set. To ensure that the HardTubes for water cooling are bent successfully, there are two 80 cm long bending inserts for HardTubes with 10 and 13 mm inner diameter. This prevents the HardTubes from bending when bending. The functions of all the tools included are described in detail in the enclosed instructions.
All the tools come in a sturdy box. To ensure that the tools are safely stored, all the tools are embedded in thick foam. This means that the tools can always be neatly packed back at the end of the work and the case can be neatly stored in the desired place.
With the Eiskoffer Light you get a perfect basis to design the hard tubes of the water cooling system according to your own wishes.
  • Dimensions: 382 x 332 x 67
  • Material bending feeder: Nylon
  • Compatible HardTube sizes: 13 and 16mm outer diameter
Scope of delivery
  • 1x Alphacool Eiskoffer Light - bending kit
€37.98 *
€28.98 *
€25.98 *
€38.98 *
€20.98 *
€39.98 *
Delivery date: in 5 - 6 weeks
