Alphacool Eiszapfen PRO 13mm HardTube Fitting G1/4 - Deep Black
  • 17471
  • 4250197174718
  • 0,041 kg
€7.48 *
€10.98*
S13 Alphacool HardTube 13/10mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€20.98*
€25.98*
SZ Alphacool Acrylic Tube Double Bending Tool 12-14mm and 16mm - Black
€17.98*
€37.98*
17565 Alphacool Eiszapfen Pro 13mm spare parts
€1.98*
The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the... more
The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the well-known Eiszapfen. When developing the fittings, Alphacool focused specifically on a specific problem: the deformation of PETG HardTubes at high temperatures. These can deform at as little as 60°C. Although such a temperature is rarely reached, it can still occur. The Eiszapfen PRO prevent this problem from the outset and hold the tubes in position.
Technical details:
  • Material: Brass
  • Colour: Deep Black
  • Diameter: 22mm
  • Height: 20mm
  • Thread: G1/4"
  • Thread length: 5 mm
  • HardTube Size: 13 mm
  • Compatibility: PETG, acrylic, brass and glass tubes
  • Weight: 0.023kg
  • Scope of delivery: 1x Alphacool Eiszapfen PRO 13mm HardTube Fitting G1/4 - Deep Black
€37.98 *
€20.98 *
€23.98 *
Delivery date: in 5 - 6 weeks
€41.98 * €59.98 *
€25.98 *
Alphacool HardTube 13/10mm 90° acrylic (PMMA) 20/40cm
Content 60 Zentimeter (€18.30 * / 100 Zentimeter)
€10.98 *
Content 240 Zentimeter (€7.49 * / 100 Zentimeter)
