  • 17475
  • 4250197174756
  • 0,174 kg
€37.98 *
Content: 6 Stück (€6.33 * / 1 Stück)
€10.98*
S13 Alphacool HardTube 13/10mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€20.98*
€25.98*
SZ Alphacool Acrylic Tube Double Bending Tool 12-14mm and 16mm - Black
€17.98*
ANS Alphacool Eiszapfen PRO 13mm HardTube Fitting G1/4 - Deep Black
€7.48*
17565 Alphacool Eiszapfen Pro 13mm spare parts
€1.98*
The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the... more
The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the well-known, previous Eiszapfen. When developing the fittings, Alphacool focused specifically on a specific problem: the deformation of PETG HardTubes at high temperatures. These can deform at as little as 60°C. Although such a temperature is rarely reached, it can still occur. The Eiszapfen PRO prevent this problem from the outset and hold the tubes in position.
Technical details:
  • Material: Brass
  • Colour: Deep Black
  • Diameter: 22mm
  • Height: 20mm
  • Thread: G1/4"
  • Thread length: 5 mm
  • HardTube Size: 13 mm
  • Compatibility: PETG, acrylic, brass and glass tubes
  • Weight: 0.023kg
  • Scope of delivery: 1x Alphacool Eiszapfen PRO 13mm HardTube Fitting G1/4 - Deep Black Sixpack
€20.98 *
€25.98 *
€23.98 *
Delivery date: in 5 - 6 weeks
€1.98 *
Content 240 Zentimeter (€7.49 * / 100 Zentimeter)
€6.49 * €8.98 *
