Alphacool Eiskoffer - Angle feeder 13mm in 45°
ZSO Alphacool Eiskoffer - Winkelanleger 13mm in 45°
  • 90348
  • 4250197137140
  • 0,022 kg
€4.97 *
45° bending feeder 2 versions for 3 dimensional bending Pipes with Ø 13 or 12 mm The... more
The horizontal angle can be freely adjusted by 180°. To do this, loosen the rear M4 screws using the included hexagon socket and set the required angle using the 1° scale. Then tighten the screws again.
Choose the right version according to the diameter of your chosen pipes.
manual
6%
€16.98 * €17.98 *
€41.98 * €59.98 *
Alphacool HardTube 16/13mm 90° acrylic (PMMA) 10/30cm
Content 40 Zentimeter (€24.95 * / 100 Zentimeter)
