Alphacool Eiskoffer - Angle feeder 13mm in 90°
- Article no.: 90349
- EAN: 4250197137157
- Weight: 0,022 kg
*190° bending feeder 2 versions for 3 dimensional bending
Pipes with Ø 13 or 12 mm
The horizontal angle can be freely adjusted by 180°. To do this, loosen the rear M4 screws using the included hexagon socket and set the required angle using the 1° scale. Then tighten the screws again.
Choose the right version according to the diameter of your chosen pipes.
