Alphacool ice case - circular arc feeder small
- Article no.: 90353
- EAN: 4250197136891
- Weight: 0,045 kg
€26.98 *
Circular arc feeder Small version Pipes with Ø 13 or 12 mm are bent by a radius of 23.5... more
Circular arc feeder
Small version
Pipes with Ø 13 or 12 mm are bent by a radius of 23.5 mm Pipes with Ø 16 mm are bent by a radius of 22 mm
Do not bend the pipe beyond an angle of 180° so that it can be removed again once it has cooled down.
All bending guides and stops are designed for pipe diameters of 12 or 13 mm and 16 mm. The required guide is always aligned downwards.
Content
15 Zentimeter
(€18.53 * / 100 Zentimeter)
€2.78
Content
15 Zentimeter
(€16.53 * / 100 Zentimeter)
€2.48
Alphacool Eiszapfen 16mm HardTube compression fitting 90° rotatable G1/4 for Acryl/Brass tubes - 4pcs Set Chrome
Content
4 Stück
(€9.00 * / 1 Stück)
€35.98
Alphacool Eiszapfen 16mm HardTube compression fitting 90° rotatable G1/4 für Acryl/Brass tubes - 4pcs Set Deep Black
Content
4 Stück
(€9.00 * / 1 Stück)
€35.98
Content
6 Stück
(€6.66 * / 1 Stück)
€39.98
Content
6 Stück
(€6.33 * / 1 Stück)
€37.98
