Alphacool ice case - starting stop with fitting depth
- Article no.: 90351
- EAN: 4250197136976
- Weight: 0,02 kg
- Available: Currently there are 8 available
Fitting stop
Stop with fixed insertion depth: 6 mm for pipes with Ø 13 or 12 mm 11 mm for pipes with Ø 16 mm
The depth is indicated by a marker
The insertion depth is designed for the slip depth of Alphacool Hard-Tube connections. You do not need to add these when transferring the dimensions. If you are not using Alphacool connections, use the straight feeder with pin stop or calculate the difference with your connections.
All bending guides and stops are designed for pipe diameters of 12 or 13 mm and 16 mm. The required guide is always aligned downwards.
