Alphacool Eiskoffer - Angle feeder 16mm in 90°
- Article no.: 90372
- EAN: 4250197137171
- Weight: 0,024 kg
90° bending feeder 2 versions for 3 dimensional bending Pipes with Ø 16 mm The horizontal... more
Pipes with Ø 16 mm
The horizontal angle can be freely adjusted by 180°. To do this, loosen the rear M4 screws using the included hexagon socket and set the required angle using the 1° scale. Then tighten the screws again.
Choose the right version according to the diameter of your chosen pipes.
Content
320 Zentimeter
(€9.06 * / 100 Zentimeter)
€28.98
Alphacool Eiszapfen 16mm HardTube compression fitting G1/4 - knurled - deep black sixpack
Content
6 Stück
(€6.00 * / 1 Stück)
€35.98
Content
240 Zentimeter
(€8.33 * / 100 Zentimeter)
€19.98
Content
30 Zentimeter
(€29.93 * / 100 Zentimeter)
€8.98
Alphacool Eiszapfen 16mm HardTube compression fitting 90° rotatable G1/4 für Acryl/Brass tubes - 4pcs Set Deep Black
Content
4 Stück
(€9.00 * / 1 Stück)
€35.98
Content
6 Stück
(€2.50 * / 1 Stück)
€14.98
Content
4 Stück
(€5.75 * / 1 Stück)
€22.98
Alphacool Eiswasser Crystal Blue UV-active premixed coolant 1000ml
Content
1000 Milliliter
€12.98
