Alphacool Eiskoffer - Angle feeder 16mm in 45°
ZSO Alphacool Eiskoffer - Winkelanleger 16mm in 45°
  • 90371
  • 4250197137164
  • 0,023 kg
€5.48 *
45° bending feeder 2 versions for 3 dimensional bending Pipes with Ø 16 mm The horizontal... more
Pipes with Ø 16 mm
The horizontal angle can be freely adjusted by 180°. To do this, loosen the rear M4 screws using the included hexagon socket and set the required angle using the 1° scale. Then tighten the screws again.
Choose the right version according to the diameter of your chosen pipes.
manual
€1.98 *
€41.98 * €59.98 *
€38.98 *
