Alphacool Core HardTube Metall Cutter 7-31mm
- Article no.: 13428
- EAN: 4250197134286
- Weight: 0,184 kg
- Available: Currently there are 7 available
With the Alphacool HardTube Metal Cutter, cutting metal tubes becomes easy. Without flex and without much effort, brass tubes, for example, can be easily processed.
Easy to use
The small, hand-operated HardTube Metal Cutter fits perfectly into any toolbox at home. Handling the cutter is uncomplicated. The first step is to clamp the tube between the rollers and the cutting blade. Then tighten the cutter blade at the desired position using the dial and slowly rotate the cutter around the tube. The cutter is regularly tightened as it moves around the pipe. That's it. This is how quickly and safely the HardTube Metal Cutter cuts.
| Technical data | |
| Dimensions (L x W x H) | 83 x 52 x 31mm |
| Weight | 180g |
| Tube diameter | 7-31mm |
| color | blue |
