Alphacool Core Heat Gun 2000W
  • 10197
  • 4250197101974
  • 0,846 kg
€29.98 *
€10.98*
18439 Alphacool HardTube 13/10mm Acryl clear 60cm - 4pcs
€15.98*
€62.98*
€25.98*
ZSO Alphacool Eistools assembly gloves size L - Black EOL
€1.48*
The Alphacool Core Heat Gun enables the bending of HardTubes. It is simple and versatile.... more
The Alphacool Core Heat Gun enables the bending of HardTubes. It is simple and versatile. Compared to the Apex version, it is a cheaper alternative that does not have an LCD display.
Easy handling
A switch on the handle allows the air speed of the Core Heat Gun to be regulated in two stages, while a rotary control allows the temperature to be adjusted. The device is designed for use in the hand or when switched off. Three different nozzle attachments for different areas of application are included in the scope of delivery.
Maximum safety
The Alphacool Core Heat Gun has feet that ensure a firm and secure stand, allowing HardTubes to be bent using both hands. The ventilation slots provide overload protection. As a temperature of up to 600°C can be reached, extreme caution is still required.
Dimensions (L x W x H)250 x 75 x 190 mm
MaterialPlastic / metal
Weight520g
Cable length160cm
Temperature control8 levels + Max Power
Temperature range60-600°C
Wind speed control2 levels
Air Output250-500L/min
Voltage230V AC
Max. power consumption2000W
Frequency50/60 Hz
Operating Temperature-10°C ~ 40°C
Storage Temperature-20°C ~ 65°C
Relative Humidity45% ~ 85%
Colorblue
€28.98 *
€25.98 *
€39.98 *
€38.98 *
€20.98 *
€41.98 *
€23.98 *
