Alphacool Molex Extractor Kit Pro - Black
  • 29136
  • 4250197136341
  • 0,037 kg
€28.98 *
KAB Alphacool Eiskamm Alu X16 - 4mm black - 4 pieces PHT EOL
€0.99*
KAB Alphacool Eiskamm Alu X14 - 4mm silver - 4 pieces PHT EOL
€2.62*
KAB Alphacool Eiskamm Alu X24 - 4mm blue - 2 pieces PHT EOL
€0.99*
MKA Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Acid Purple (Paracord 550 Type 3) 330cm EOL
€1.98*
MKA Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Colonial Blue (Paracord 550 Type 3) 330cm EOL
€1.98*
MKA Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Neon Green (Paracord 550 Type 3) 330cm EOL
€1.98*
The world-famous water cooling manufacturer Alphacool International is also the first choice in... more
The world-famous water cooling manufacturer Alphacool International is also the first choice in the modding field: With this Molex Extractor Kit, the common terminals (pins) of Molex (4 pin), fan connectors (3 and 4 pin) and ATX/PCie connectors (4-24 pin) can be easily removed.
When pushed over the pin, the tools help to push back the protruding retaining brackets that hold it in the connector housing so that it can be pulled out again.
The Alphacool Molex Extractor Kit also contains a wire sleeve into which the cable end to be sleeved can be inserted and the sleeve can be easily guided over it. With this set, every cable modding is simply fun because it allows you to work easily and safely.
Scope of delivery
  • 1x female tool
  • 2x male tool
  • 1x ATX tool
  • 1x Sleeving needle
Datasheet
62%
hose cutter aluminum replacement blade 3-19mm
€0.99 * €2.59 *
€0.99 * €4.89 *
€0.99 *
75%
€0.99 * €3.99 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - White (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Electric Blue (Paracord 550 Type 3) 330cm
€1.98 *
€1.98 *
56%
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Acid Purple (Paracord 550 Typ 3) 330cm EOL
€1.98 * €4.47 *
Alphacool Eiskamm Alu X16 - 4mm blue - 4 pieces
Content 4 Stück (€0.72 * / 1 Stück)
€2.88 *
60%
Alphacool Eiskamm Alu X8 - 4mm blue - 4 pieces
Content 4 Stück (€0.66 * / 1 Stück)
€2.64 * €6.59 *
€0.99 * €5.02 *
Phobya VGA Power Connector 6+2Pin plug incl. 8 pins - 2 pieces Black
Content 2 Stück (€1.44 * / 1 Stück)
€2.87 *
€1.89 *
€1.98 *
