Alphacool Eisbaer - Refill Kit
  • 11687
  • 4250197116879
  • 0,044 kg
11285 Alphacool Eisbaer 240 CPU - black
€125.98*
11286 Alphacool Eisbaer 360 CPU - Black
€149.98*
11445 Alphacool Eisbaer LT240 CPU - black
€119.98*
11446 Alphacool Eisbaer LT360 CPU - black
€132.98*
Customize your Alphacool Eisbaer, make it YOUR all-in-one – with the new Alphacool Eisbaer –... more
Customize your Alphacool Eisbaer, make it YOUR all-in-one – with the new Alphacool Eisbaer – Refill Kit!
Fill your AiO as you wish!
Personalize your Alphacool Eisbaer All in One to suit your system. Fill it as you wish and vary the liquids. Thanks to the pre-assembled G1/4'' thread, clean work is guaranteed.
Start the power supply safely!
Alphacool has included the ATX jumper plug for particularly safe working. This means you can start your power supply without a motherboard and your pump is no longer connected to the rest of the system. A SATA to 3-pin pump connector is included.
Thermal paste for best cooling results!
With the high-end thermal paste from Alphacool, you always achieve the best cooling results. It provides clean contact between the CPU and your cooler and optimizes your cooler for full performance.
  • 1x ATX jumper plug
  • 1x funnel with G1/4“ screw thread
  • 1x SATA to 3-pin pump connector
  • 1x syringe with thermal paste
Technical data sheet
7%
Alphacool Eisbaer screw kit M3 x 5/M3 x 30mm
Content 18 Stück (€0.33 * / 1 Stück)
€5.98 *
€6.49 * €8.98 *
