Alphacool Eisbaer GPX Extension Set 90° (hose and connections)
- Article no.: 12542
- EAN: 4250197125420
- Weight: 0,253 kg
With the Eisbaer Quick-Connect Extension Set, the circuit of an Eisbaer or Eiswolf GPX-Pro cooler can be easily expanded to include additional components. For example, with another radiator, another cooler or other components.
The set consists of two 32cm long hoses in 11/8 format and are covered with anti-kink springs. This prevents the hoses from kinking and thus prevents the water from flowing too far. Safety is a top priority.
At two ends there are 90° angles that are pre-mounted on the hoses. All you have to do is screw them into the corresponding G1/4" threads. At the other end there are two ends of a safety quick release from the Alphacool HF series, just like the ones you find on the Eisbaer or Eiswolf. This means you simply open the quick release on the Eisbaer or Eiswolf and screw them together with the matching counterparts from this set and another product, and the circuit is complete. Of course, this still needs to be filled.
Technical details:
- Hose length: 32cm
- Quick connector material: nylon
- Color: black
- G1/4" thread
- 11/8 hose size
- Alphacool Eisbaer GPX Extension Set 90° (hose and connections)
Delivery date: in 5 - 6 weeks
