  • 15361
  • 4250197153614
  • 0,014 kg
€5.48 *
Content: 60 Zentimeter (€9.13 * / 100 Zentimeter)
PUZ Alphacool Eisdecke Laing DDC Acrylic Top V.2
€31.98*
PUZ Alphacool Eisdecke D5 attachment - acrylic G1/4 - (VPP755/VPP655/TPP644/MCP655) V.3
€34.98*
LED Alphacool Aurora LED RGB connector 90° - Black EOL
€1.18*
The new Alphacool Twin LED RGB cable gives you unlimited possibilities for expanding your RGB... more
The new Alphacool Twin LED RGB cable gives you unlimited possibilities for expanding your RGB setup. These LEDs can be fully controlled with the various Aurora controllers via the 4-pin RGB connector.
With a diameter of 5mm, this cable is compatible with all common 5mm LED holes in CPU coolers and expansion tanks, which opens up a wide range of possible applications.
  • Length: 30cm
  • LED diameter: 5mm
  • Connector: 4-pin RGB
39%
23%
Alphacool Aurora LED Flexible Light incl. Controller - RGB 30cm
Content 30 Zentimeter (€33.27 * / 100 Zentimeter)
€9.98 * €12.98 *
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
€0.99 * €4.89 *
42%
Hint!
€1.48 *
54%
Alphacool RGB 4-pin LED adapter cable for motherboards - Black 50cm
Content 50 Zentimeter (€3.96 * / 100 Zentimeter)
€1.98 * €4.28 *
23%
€9.98 * €12.98 *
€83.98 *
