Alphacool Eisdecke Laing DDC Acrylic Top V.2
  • 13186
  • 4250197131865
  • 0,338 kg
13179 Alphacool Laing DDC310 - Single Edition - black
€69.98*
PUZ Alphacool Eisdecke DDC/D5 expansion tank individually for Alphacool Eisdecke
€31.98*
€64.99*
13996 Laing DDC-pump 12V DDC 4.2 PWM
€74.98*
PUZ Alphacool decoupling set Eheim/Hydor/Laing attachment 4 buffers
€6.98*
The tried and tested Laing DDC attachment is now available in a new version. This attachment... more
This attachment has been a benchmark for years. Small improvements have been made time and again. The first major update differs in a few details, both visually and technically.
The principle: On the bottom there is space for the Laing DDC pump, which is separate from the original attachment, and the inlet and outlet at the front or on the top.
For even more flexibility, the ice cover has three inlets and two outlets. Another feature is the new bracket to give the whole unit a stable stand and round off the overall visual appearance. Optional installation in a 3.5" slot is still possible.
The attachment can be converted into a complete expansion tank using the expansion tank attachment available as an accessory, which has also been redesigned.
For all case modders, the acrylic glass attachment has four holes for 5mm LEDs!
Technical data:
  • Dimensions: 80 x 80 x 23mm
  • Material: Acrylic
  • Connections: 5x 1/4" thread
  • 1x Alphacool Eisdecke Laing DDC acrylic attachment V.2
  • 3x locking screw 1/4"
  • 2x feet
  • Mounting material
Assembly instructions
Note on assembly: After assembly, a small gap remains between the pump and the cover. The seal is ensured because the O-ring forms a positive connection here. Therefore, do not tighten the screws too tightly, as this can cause damage to the cover.
€2.48 *
33%
€5.99 * €8.98 *
€5.48 *
Alphacool stand for ice blanket/ice cup series - black
