- Article no.: 18654
- EAN: 4250197186544
- Weight: 1,1 kg
With the Apex Liquid, Alphacool fulfills the wishes of many modders and water cooling enthusiasts. The red glowing coolant creates great effects in Plexi coolers, tubes and expansion tanks. It has excellent UV-reactivity with UV-LEDs or cathodes. In this product, we completely avoid dangerous and aggressive ingredients. As a result, Alphacool Apex Liquid is ecologically safe and can be disposed of safely if necessary. With Alphacool Apex Liquid you treat your water cooling system to a visual highlight with the best cooling performance.
Application
The liquid is a ready-mix and can be used directly from the bottle.
Properties
The additives contained effectively protect the water loop from corrosion, lime and other contaminants and minimize the surface tension of the liquid, which makes it easier to dissolve bubbles in the loop. An additional positive side effect is that the pump is lubricated and its service life is thus significantly extended.
No restrictions
Alphacool Apex Liquid is suitable for all materials that are usually included in the water loop of a water cooling system. This includes materials such as copper, brass, nickel, chrome plating, aluminum, POM, PPS-GF40, PETG, acrylic, PVC and EPDM/PP.
Notes
It is essential to avoid adding other biocides or anti-corrosion fluids, as well as diluting the fluid with distilled water, otherwise the basic and coordinated properties of the fluid will be lost. It should also be noted that when using this colored coolant, the water loop must be cleaned more frequently. The dyes it contains can clog the circuit after a long period of use and impair cooling performance. Therefore, Alphacool's Apex Liquid is more suitable for use in show cases rather than gaming or work PCs.
| Technical data | |
| Ingredients | 95 % distilled water | 4.2 % Glysofor L | 0.7 % Rhoba Clear | 0.1 % colourant |
| Properties | UV-active | good thermal conductivity | low electrical conductivity | pre-mixed material |
| Container | 1000 ml |
| Color | red |
Due to the intensity of the colours, clothing or other materials that come into contact with the coolant may become discoloured. This must be taken into account when using the product. It is advisable to proceed carefully when filling the circuit with the cooling liquid.
