  • 18548
  • 4250197185486
  • 1,1 kg
Content: 1000 Milliliter
S13 Alphacool Ice Tube 13/10mm PETG HardTube 80cm - Set of 4 (320cm)
€23.98*
€19.98*
S13 Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Red 1m (3.3ft) Retailbox 100cm
€7.98*
€16.98*
WZS filling aid - plastic funnel
€4.99*
With Alphacool Eiswasser, water cooling pioneer Alphacool is checking off every modder and... more
Colortransparent
UV inkblue
Content1000ml
SpecificationReady mix
ManufacturerAlphacool
Alphacool Eiswasser Crystal Yellow premixed coolant 1000ml
€23.98 *
Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Blue transparent 3m (9.8ft) Retailbox 300cm
