  • 18671
  • 4250197186711
  • 5,1 kg
Content: 5000 Milliliter (€16.00 * / 1000 Milliliter)
€62.98*
WZS Alphacool pumpin gum ball - black
€10.98*
€36.98*
WZS Alphacool Apex filling funnel G1/4"
€8.98*
With ES Liquid GL50, Alphacool offers an industrial cooling liquid for high-performance cooling.... more
With ES Liquid GL50, Alphacool offers an industrial cooling liquid for high-performance cooling. Due to its composition, it protects against deposits, can flow easily through all types of rubber and plastic parts, and has a low maintenance requirement. Servers and workstations, in particular, benefit from these properties.
Maximum performance!
Alphacool's ES Liquid GL50 industrial cooling liquid is designed for temperatures between -40°C and 90°C. The thermal conductivity is reliable and at the highest level even at extreme temperatures. Foam formation is also not to be feared as the high-stress cooling liquid effectively prevents it. Despite its blue color, no deposits occur. On the contrary, ES Liquid GL50 protects the system sustainably and thus ensures low maintenance and high durability.
Protection
Alphacool's GL50 provides reliable protection for the metals and alloys used in water cooling systems. Additionally, the specially formulated liquid effectively prevents high-temperature corrosion on aluminum surfaces. However, it is important to avoid using a mix of pure copper and aluminum in the same cooling loop. Plastic and rubber components, such as tubes, do not react with the liquid. GL50 is free of nitrates, phosphates, and amines.
Do not mix!
As it is a silicate liquid, it does not contain nitrates, phosphates, or amines. This means that no rubber or plastic is attacked and the product can be used neutrally in any system. However, it is important that ES Liquid GL50 must not be mixed with other liquids! If it is mixed, the warranty will be voided and its properties may be negatively affected.
Filling quantity5000ml
Boiling point90°C
Freezing point-40°C
Service life3 Years
Type of liquidSilicate liquid
ContainsEthylenglycol, Diethylenglycol
Colorblue
Note on use
WarningMust not be mixed with other liquids!
Safety notes
Warning
  • Harmful if swallowed.
  • Wash hands thoroughly after handling.
  • Do not eat, drink or smoke when using this product.
  • IF SWALLOWED: Call a POISON CENTER/doctor if you feel unwell.
  • Rinse mouth.
  • Dispose of contents/container according to local/national/international regulations.
Alphacool Eiswasser Crystal Yellow premixed coolant 1000ml
€69.98 *
Alphacool ES Orbiter 360 TS
€549.98 *
€34.98 *
17%
RAK Alphacool ES Chiller 1000
€578.98 * €699.98 *
