  • 18550
  • 4250197185509
  • 1,1 kg
Content: 1000 Milliliter
With Alphacool Eiswasser, water cooling pioneer Alphacool is checking off every modder and... more
UV inkNot UV active
Content1000ml
SpecificationReady mix
Colorgreen
ManufacturerAlphacool
Alphacool Eiswasser Crystal Yellow premixed coolant 1000ml
€69.98 *
€25.98 *
€28.98 *
