- Article no.: 18549
- EAN: 4250197185493
- Weight: 1,1 kg
Notes
It is essential to avoid adding other biocides or anti-corrosion fluids, as well as diluting the fluid with distilled water, otherwise the basic and coordinated properties of the fluid will be lost.
| Technical data | |
| UV ink | Not UV active |
| Content | 1000ml |
| Specification | Ready mix |
| Color | red |
| Manufacturer | Alphacool |
