Alphacool Eisfluegel flow indicator G1/4 square - acetal
  • 17350
  • 4250197173506
  • 0,093 kg
€6.98*
17228 Alphacool Eiszapfen 13/10mm compression fitting G1/4 - deep black sixpack
€35.98*
S13 Alphacool hose AlphaTube HF 13/10 (3/8"ID) - Clear 1m (3.3ft) Retailbox 100cm
€6.98*
Alphacool Eisflügel: The flow indicator with added value! Water cooling in a computer always... more
Water cooling in a computer always serves to improve the appearance. Neatly laid hoses or hard tubes create an impressive image. The Alphacool ice wing can also be used to create a real eye-catcher. The silent rotation of the impeller always shows the direction of flow.
The combination of acetal and acrylic glass is a successful combination that fits seamlessly into any system. In addition to the two 1/4" threads that are necessary for the water to flow through, the Alphacool Eisflügel has another thread on the top that can be used for many purposes: lighting, fill port, drain port or as an angle piece - the function is also guaranteed if the upper thread is used as an outlet.
The impeller with six blades inside is also made of acrylic glass, with the front sides marked in two different colors, blue and yellow. Depending on the color of the liquid, the side with the stronger contrast can be selected.
Technical Data
Dimensions (LxWxH)44,5 x 32,1 x 48,4mm
MaterialAcetal, Acrylic, Nylon
Threads3x G1/4"
FlügelradfarbeYellow, blue
GehäusefarbeBlack, transparent
€28.98 *
