Alphacool Eisfluegel flow indicator blue 6-11mm - acrylic
  • 17356
  • 4250197173568
  • 0,019 kg
18543 Alphacool Eiswasser Crystal Blue UV-active premixed coolant 1000ml
€12.98*
Alphacool Eisflügel: The flow indicator with added value! Water cooling in a computer always... more
Water cooling in a computer always serves to improve the appearance. Neatly laid hoses or hard tubes create an impressive image. The Alphacool ice wing can also be used to create a real eye-catcher. The silent rotation of the impeller always shows the direction of flow.
Technical data:
  • Dimensions: 88 x 40 x 15mm
  • pressure load up to 2 bar, max.
  • Connection: for hoses with an inner diameter of 6-11mm.
  • Material: ABS
  • 1x Alphacool Eisfluegel flow indicator blue 6-11mm - acrylic
Alphacool Eisbaer screw kit M3 x 5/M3 x 30mm
Content 18 Stück (€0.33 * / 1 Stück)
€5.98 *
€1.89 *
€1.48 *
€6.99 *
