Alphacool Eiswasser Crystal Blue UV-active premixed coolant 1000ml
  • 18543
  • 4250197185431
  • 1,1 kg
Content: 1000 Milliliter
With Alphacool Eiswasser, water cooling pioneer Alphacool is checking off every modder and... more
UV inkblue
Content1000ml
SpecificationReady mix
Colorblue
ManufacturerAlphacool
Alphacool Eiswasser Crystal Yellow premixed coolant 1000ml
€69.98 *
Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Blue transparent 3m (9.8ft) Retailbox 300cm
€28.98 *
