  • 13093
  • 4250197130936
  • 9,94 kg
€439.98 *
13016 Alphacool Core Loop Cleaning 100ml
€9.98*
11932 Alphacool ES Orbiter 360 TS
€549.98*
€36.98*
The ES Orbiter Filling Station from Alphacool allows for easy and effective filling of water... more
The ES Orbiter Filling Station from Alphacool allows for easy and effective filling of water cooling systems. With the help of the two powerful pumps, the system to be filled is quickly vented. A high-performance filter ensures that the coolant is cleaned, making the ES Filling Station also ideal for cleaning cooling loops.
Efficient venting and filtering
The two built-in pumps in the ES Filling Station not only ensure redundancy, but also enable fast and reliable venting of the system to be filled. The installed filter ensures that no impurities enter the cooling system. Thanks to the filter, the Filling Station is also ideal for cleaning existing cooling circuits.
Easy handling
Filling the Alphacool ES Filling Station is effortless via the slightly raised G1 filling port. The illuminated inspection window allows easy monitoring of the fill level at any time and even in poorly lit environments. The integrated reservoir has a capacity of approx. 4500 ml. In addition, the Filling Station has a maintenance door for carrying out work such as changing filters.
Dimensions (L x W x H)415,50 x 226,40 x 188,10mm
Material: CaseMetal
Material: ReservoirAcrylic
Material: TubesTPV (EPDM)
Approved liquidswater, water/glycol mixture
Voltage12V DC
Power consumption39W
Approved water pressure0,8bar
Max. pumping height3,125m
Rate of flow350l/h
Permitted operating temperature (industrial applications)75°C
Water connections2x G1/4“
Diameter filling portG1“
Volume reservoirapprox. 4500ml
KOE Alphacool Eiswand 360 Solo - Black
Alphacool Eiswand 360 Solo - black
€356.98 *
€549.98 *
38%
RAK Alphacool ES Chiller 1000 ServerRack 5HE
Alphacool ES Chiller 1000 ServerRack 5U
€999.98 * €1,599.98 *
€25.98 *
€2.68 *
€28.98 *
