Alphacool Eiswand 360 Solo - black
- Article no.: 11459
- EAN: 4250197114592
- Weight: 7,681 kg
*1The Eiswand is Alphacool’s complete water cooling set for your CPU.
The core component of the Eiswand is the external 360mm full-copper radiator, which is equipped with six Eiswind fans. This means the system’s cooling power is very high, enough for any combination of CPU and GPU. Copper offers double the heat capacity of the aluminium often used in cheap systems. The six Eiswind fans are built to operate in Push&Pull configuration, to guarantee optimal radiator ventilation.
The illuminated reservoir sits directly on the external radiator. There, the fill level can easily be checked through the large viewing window, and the fill port on the upper surface makes it easy to fill the loop.
The elegant, likewise illuminated bottom of the Eiswand contains two DC-LT silent pumps, which are also used in several of Alphacool’s other systems. For example, they are used in the Alphacool Eisbaer, often praised for its low noise level. The pumps’ capacity is so high that even if one of them fails, there is no noticeable loss of cooling power. One pump is strong enough to keep a simple cooling loop going. This guarantees top-level security for your whole system.
| Technical data | |
| L x W x H Eiswand | 210 x 155 x 534 mm |
| Radiator | 1x 360mm XT45 full-copper radiator |
| Fans | 6x Eiswind fans 1100/700 RPM |
| Color | black |
