Alphacool Eiszapfen quick release coupling set with double bulkhead screw connection G1/4 IG - Deep
- Article no.: 17368
- EAN: 4250197173681
- Weight: 0,11 kg
Alphacool's new quick couplings called "Icicles" are the next building block in the "Ice" series. High quality and impressive features make every water cooling system a little more valuable and practical!
A quick-release coupling is used wherever expandability, flexibility or cleanliness play a major role. These compact couplings have a 1/4" thread on both sides, making them compatible with all common connections.
These couplings are separated by pulling down the outer ring. Both sides immediately seal completely so that no more water can escape. The special NDSL technology (no drip, no splash, no leak) prevents water from leaking, dripping or splashing out when the cap is opened. When reconnecting, both sides audibly click into each other and seal tightly with a double O-ring, which is simply pressed together when connected. This also prevents the O-ring from wearing out. The mechanism has also been designed for durability to ensure a secure connection even after years.
Many quick couplings also affect the flow. But Alphacool has found a way to solve this problem. These quick couplings maintain a high flow rate!
Alphacool's quick couplings are available in two versions. In deep black and completely chrome-plated, they fit seamlessly into any system.
Technical data:
- Dimensions (L x D): 64.6 x 23.9mm
- Material: Brass
- Colour: Deep Black
- Thread: 2x 1/4" IG
- 1x Alphacool Eiszapfen quick release coupling set with double bulkhead screw connection G1/4 IG - Deep Black
The quick couplings should not be used permanently in a dry state, as the O-rings would otherwise be subjected to excessive stress and would no longer be leak-proof.
