Alphacool RGB 4-pin LED adapter cable for motherboards - Black 50cm
  • 18540
  • 4250197185400
  • 0,1 kg
€1.98 * €4.28 * (53.74% Saved)
Content: 50 Zentimeter (€3.96 * / 100 Zentimeter)
This cable is a simple solution to connect motherboards from ASUS, Gigabyte or MSI to your RGB... more
This cable is a simple solution to connect motherboards from ASUS, Gigabyte or MSI to your RGB lighting. This way you can easily synchronize and control your RGB lighting via your motherboard's software!
Also compatible with the Thermaltake TT Sync Controller and cases from various manufacturers.
Scope of delivery
  • 1x Alphacool RGB 4-pin LED adapter cable for motherboards 50cm - Black
83%
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 30cm
Content 30 Zentimeter (€3.30 * / 100 Zentimeter)
€0.99 * €5.89 *
KAB Alphacool Eis-Matrix Verbindungskabel - 10cm EOL
Alphacool Ice Matrix connection cable - 10cm
Content 10 Zentimeter (€9.90 * / 100 Zentimeter)
€0.99 *
€0.99 * €4.89 *
€1.48 *
51%
Alphacool Eis-Matrix connection cable to 4-pin RGB - 10cm
Content 10 Zentimeter (€9.80 * / 100 Zentimeter)
€0.98 * €1.98 *
€2.28 *
60%
WACZ Alphacool Aurora XPX RGB Frame - Black PHT EOL
€3.99 * €9.95 *
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
€6.99 *
€5.48 *
€1.78 *
Delivery date: in 2 - 3 weeks
€2.78 *
€39.98 *
60%
WACZ Alphacool Aurora XPX RGB Frame - Chrome PHT EOL
€3.99 * €9.95 *
17%
86%
KAB Alphacool Y-Kabel RGBW 5pol auf 3x 5pol inkl. Stecker - Schwarz 60cm EOL
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 60cm
Content 60 Zentimeter (€1.65 * / 100 Zentimeter)
€0.99 * €6.89 *
