Alphacool Aurora XPX RGB Frame - Chrome
- Article no.: 12932
- EAN: 4250197129329
- Weight: 0,034 kg
- Available: Currently there are 4 available - More is on the way
A perfectly illuminated CPU water cooler is a real eye-catcher in every water-cooled gaming PC. The Alphacool Aurora XPX RGB Frame is the perfect solution for lighting the Eisblock XPX Plexi clear or satin CPU water cooler.
The RGB frame is simply placed on the Eisblock XPX Plexi CPU cooler and connected to a suitable RGB controller. With an incredible 15 RGB LEDs evenly distributed around the Eisblock XPX Plexi CPU water cooler, perfect lighting is guaranteed.
An RGB controller not only allows you to change the color, but also to create color effects such as overflows, flashing, slow color changes and much more. The LEDs can of course also be dimmed. This makes the Alphacool XPX RGB frame an all-rounder in RGB lighting.
With the 4-pin male 12V RGB connector, all Alphacool RGB products are compatible with the common RGB sync technologies of all well-known motherboard manufacturers (ASUS ROG Aura Sync, ASRock RGB LED, MSI Mystic Light and GIGABYTE RGB Fusion). However, you may need an adapter cable, depending on whether the motherboard uses a male or female connector. Alternatively, you can also use the Alphacool Aurora LED RGB controller, the easiest method to control the Aurora XPX RGB Frame.
- Dimensions: 75 x 75 x 17 mm
- Cable length: 40 cm
- Connector: 4Pin RGB
- Material: POM Chrome
- Number of LEDs: 15
- Control: separate RGB control (not included)
Scope of delivery
- 1x Alphacool Aurora XPX RGB Frame - Chrome
Delivery date: in 6 - 7 weeks
