Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 60cm
  • 18570
  • 4250197185707
  • 0,032 kg
€0.99 * €6.89 * (85.63% Saved)
Content: 60 Zentimeter (€1.65 * / 100 Zentimeter)
LED Alphacool Aurora LED RGBW connector 90° - Black EOL
€0.99*
The new Alphacool Y-cable for 5-pin RGBW connections allows up to three individual RGBW... more
The new Alphacool Y-cable for 5-pin RGBW connections allows up to three individual RGBW components from the Alphacool RGBW family to be combined into one input. This means that these three components can be connected to an RGBW output from, for example, a motherboard, graphics card or RGBW controller using an Alphacool Y-cable. This means that RGBW solutions such as ASUS AURA, MSI MYSTIC LIGHT or GIGABYTE/ AORUS RGB FUSION can be used to synchronize Alphacool RGBW products.
The cable comes with 4 male / female connector bridges.
  • Connection
    Side 1: 1x 5-pin
    Side 2: 3x 5-pin
  • Design: Y-cable
  • Length: 60cm
  • Sleeve: black
  • 4x male connector
scope of delivery
  • 1x Alphacool Y-cable RGBW 5-pin to 3x 5-pin 60cm incl. plug - black
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 30cm
Content 30 Zentimeter (€3.30 * / 100 Zentimeter)
€0.99 *
€0.99 * €4.89 *
€1.78 *
Delivery date: in 2 - 3 weeks
€5.99 *
€3.47 *
€6.99 *
54%
Alphacool RGB 4-pin LED adapter cable for motherboards - Black 50cm
Content 50 Zentimeter (€3.96 * / 100 Zentimeter)
€1.98 * €4.28 *
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
€28.98 *
€3.98 *
32%
Alphacool Apex Thermal Pad Soft 18W/mk 120x20x1,5mm
Content 24 cm² (€1.41 * / 1 cm²)
€33.88 * €49.98 *
WAC Alphacool Core 1 Silver
45%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x1,5mm
€16.48 * €29.98 *
€6.99 *
€5.68 *
€2.98 *
€2.78 *
€2.58 *
€1.68 *
€1.48 *
Alphacool extension JST aRGB 3-pin to 3-pin 15cm
Content 15 Zentimeter (€8.60 * / 100 Zentimeter)
€1.29 *
€5.28 *
€4.38 *
